supercub's avatar
supercub
Front Airbags not filling at idle??
I start the motor home in the morning and let idle to let it warm up. The rear bags inflate to above 100PSI. The fronts only go to about 60psi. As soon as I go about 100 feet the fronts inflate to above 100PSI. Just started having this problem. I don't know if it's extra power or moving the motor home. Tomorrow, I'll try giving it a little power before moving to see what happens. Once the pressure comes up, it holds stable. Is there a sensor that might be sticking? or ?? Any help? Thanks
Brian
