Trackrig
Dec 18, 2014Explorer II
Are the air gauges for the pressure in the front and rear air tanks or are they for the air suspension? I haven't seen gauges for telling you the pressure in the air bags - but then I certainly haven't seen every type of MH!
And then do the rear air bags fill off of the rear air tank and the front air bags fill off of the front air tank? Do both sets of air bags fill off of one tank? Do the air bags even fill off of the brake air tanks or does their air come straight from the air compressor? I ask these questions because I don't know and maybe someone with more knowledge can give an answer.
Never the less, I would expect that if the rear air tank is at 100PSI, the front should be a lot closer than 60 PSI. Every MH or truck that I've driven with air brakes always fill the tanks a lot more evenly than that. Usually the difference is only 5 - 10 PSI which just might be the gauges themselves.
Bill
Bill
38,780 PostsLatest Activity: Jul 04, 2015
