I have a Mandalay Presidio coach. After a weekend of tailgating and the front door being slammed continuously, the door seems sprung. It is very hard to close and getting worse. Anyone had this pro...
Does your year model Mandalay have the air assisted door gasket or the air assisted top lock latch? If the frame assisted air lock latch malfunctions or the nylon lock has broken it will cause these type problems. To see if you have the air assisted lock latch you look at the top area of the door frame and you will see a round roller and on the door frame a nylon guide. Doug
