I have a Mandalay Presidio coach. After a weekend of tailgating and the front door being slammed continuously, the door seems sprung. It is very hard to close and getting worse. Anyone had this pro...
Measure the door opening to check to see if it has changed. The width at the bottom should be the same at the latch height. Examine the door hinges to see if any screws are loose by opening the door and then trying to lift the door at the bottom to see if there is any looseness with the hinges. If the door moves up and down when opened, it indicates a hinge problem.
