10forty2's avatar
10forty2
Front End Alignment
Taking my rig to a truck shop on Wednesday to get an alignment. It doesn't pull to either side, but the steering is a little more loose than I would like and I also want to see if there's any help the alignment can give me when it comes to sway from trucks/cars. I will likely get the tech to do the Cheap Handling Fix while he's under there as well. I have previously replaced the OEM sway bar bushings with poly bushings, which made a world of difference in the amount of sway since the OEM bushings were practically gone. They will also check the rear axle alignment and leaf springs.
I've read that they should set the caster to the upper end of the specs, and in talking to him on the phone to make the appointment, he had already mentioned that as one solution. Anything else to ask him to look for while under the rig?
