tropical36
Oct 19, 2013Explorer II
darin338 wrote:harold1946 wrote:tropical36 wrote:harold1946 wrote:tropical36 wrote:darin338 wrote:
Ah you all gotta love us newbies. Full of ignorant questions. :) and I've got another! Maybe a few more.
Just purchased our 2000 Newmar dutch star on a p30 chassis with a gmc 7.4.
The owner indicated the front airbags might be in need of replacing but he said it should be fine for our journey home some 540 miles away. WRONG! I did notice the front end seemed to be sitting a little low, but was assured it'd be ok.
I got out on the highway and about 30 miles down the road we went over a bridge with the big hump/ hump in the road. The front end tires must have hit the wheel well as it sounded like the world was ending and I could feel it in my seat. Something was either grinding or coming apart up under there. I pulled off and got out and now the front end looked to be sitting down so low that about 1/3 or more of the front tires were covering the front tires. Luckily there was a camping world about five miles away with a full service center.
Camping world can replace the airbags and will check things over under there. Not sure if they can fix major stuff up in the front end or not, we will see.
The other question is the brakes, they're mechanical and while they work to stop the coach, this does not seem normal. Do 2000 rv's still come with mechanical brakes?
The only other known issue at this time is the thermostat gauge is stuck about 150 and seems to be broke. Asked them to check this out as well. Hope the previous owner didn't fixate it there to avoid me seeing it overheat. Seemed to run fine otherwise.
Don't waste your time and money with the air bags and have camping world install the proper per front end weight....HENDERSON SUPER STEER...coils
Don't know what you mean by mechanical brakes as they went out with the Model A Ford. What you have are hydraulic brakes with power assist that is being supplied by the same pump as your power steering is. May not be as easy on the pedal as your vacuum assist car, but still pretty effective, as long as you don't tailgate or even drive anywhere close to anyone in front of you.
Why is it a waste of time and money to replace the airbags:@ Are you saying the GM and Workhorse engineers were all wrong. :S
Had nothing to do with GM and with so many others chopping up the chassis and using them for many different applications. I'm most sure this is something that the coach manufactures did to try and accommodate for the lesser cost and most profit. They weren't about to weigh every coach, fully loaded with gear and people and then install the proper weight coils for each and every unit. Many have even replaced these stupid bags when the coils were completely fatigued, so the proper ride height could never be attained and making alignment impossible. Now thats really throwing it down the drain. Who wants to be continuously monitoring the air anyway and especially when you're out there going across country. I mean, it's seldom that the system will let you know as soon as one decides to go limp on you, so do you check them every day or what?.
You have been mis-informed. The P series chassis was designed with air assisted suspension so it could be easily adjusted for the suspension loading by different coach manufacturers without having to change out springs.
Its realy as simple as checking the pressure in tires but many are too lazy to do that also. The coils become fatigued because someone failed to maintain minimum pressure. It was a GM design.
There are pressure guages and onboard compressors available that make it possible to monitor and adjust pressure from the drivers seat. It was an option on many coaches and few chose to have it installed. I had that option on our Airstream Land Yatch.
I'm gonna call camping world and ask to have the monitor installed. So is the airbags likely the culprit for the front end riding so extremely low then? I mean the coach on the front end was maybe 12 inches off the ground and half the tire covered by the wheel well?
Sounds like something broke in two if it's that bad, but I will tell you this and you can take this to the bank, no matter what the reason behind the air bags, even though everything usually has an economic basis of some sort, if your coils are fatigued and/or collapsed, no amount of air in any new bag (90psi max) is going to restore the ride height to proper specs. and as a result, will be impossible to have the front end aligned. So, you can either install the super steers and be done with it for good or you can install new OEM coils and the air bags as well, which usually have a life of about 3 yrs.. Your choice!
Please let us know of your findings with camping world.
