tropical36
Oct 22, 2013Explorer II
aadam56 wrote:
Hi,
You just need new heavy duty coils springs AND airbags, a set of shocks. labor should be the same since they have to dis assemble the same things to change the airbags. you don't need a monitoring system. just fill them up to about 60 lbs. and check them when you check your tires like one of the other post said.
The brakes feel like mechanical brakes but with the right power steering fluid and brake fluid they will stop.just have them check them to be safe.
Good Luck and have fun :)
Why are you recommending air bags along with proper and weight selected coil springs and you certainly wouldn't disassemble the coils if you were to just change the airbags? Don't know how many you've done or have seen installed, but I just don't see where you're coming from with these recommendations for the OP, who should be pretty confused as it is by now. Just wondering if you read each and every post before commenting?
