Gjac
Oct 22, 2013Explorer III
What is your ride height now? You should have about 1 3/4 ins between the lower rubber bumper and the upper A arm. If not try jacking the MH all the way up then inflate your airbags if you still don't get the ride height after you lower the jacks then go with the Henderson super springs. Worn ball joints or other worn front end parts will cause a bad ride also.
