dougrainer
Jun 11, 2017Nomad
If you can feel it in your feet, the most obvious thing to check is the support steel bars that the OEM uses to modify and support the items they install in the front end box. If just 1 small weld has failed or they forgot, this one piece of steel can move. It moves just enough to then partially stick and when it pops loose, it makes a pop sound that you can feel in your feet. This can be either the Pass side or the drivers side, the noise/pop can easily move to the other side and sound like it is on just 1 side. I use a long, heavy duty pry bar to check every welded steel piece in the front end to find such problems. Doug
