- MountainAir05Explorer IIHave fun. We are watching our annual Albuquerque balloon festa(on TV)this morning.
- TomandCandyExplorer
TomandCandy wrote:
front fan burned up today going clam digging in a couple of days is it ok to drive with front fan not working I was able to unplug the wires don't under stand air condition how it works I have a rear diesel cummins engine. this is the one for the ac seems to get warm with engine running thanks Tom
(CLAM DIGGING IS ON) found ac condenser fan at local auto parts for about 1/3 the price and it bolted right up and works fine how lucky was that later Tom - dodge_guyExplorer IIThat is the AC condenser. If you unplugged it then you are good to go. As you said the radiator, inter cooler and trans cooler are in the rear.
- TomandCandyExplorerThis ac radiator condenser is up front I have a rear radiator, rear air cooler, and rear transmission cooler in the back I'm not sure if the heater and air are together I'm going to try and find one tomorrow or more info
- MountainAir05Explorer IIis this fan for the heater and air conditioner. You are not talking about the fan on the engine are you. if yes No you can not drive it. If for the heater then unless you need heat or the AC yes you can drive it. Does this have anything to do with the new radiator you were looking for. Post back before you do anything with your answers.
- bgumExplorerI would call Cummins.
38,779 PostsLatest Activity: Jun 16, 2026
