ron_dittmer
Jun 24, 2021Explorer III
If your rig moves a lot when parked, then it moves a lot when being driven. So if you are thinking you need stabilizer jacks, you might benefit from heavy duty front and rear stabilizer bars also called sway bars.
Motorhomes built on the Ford E350 model 2007 and older, don't have any kind of rear stabilizer bar unless added by a previous owner. If you lack a rear stabilizer bar, adding a heavy duty one will significantly reduce the need for stabilizer jacks.
CLICK HERE for instruction on a simple test you can perform to help determine if you could benefit from such suspension upgrades.
38,782 PostsLatest Activity: Sep 10, 2026
