jschmelzer's avatar
jschmelzer
Front wheels of ground after using auto-jacks
On our first shakedown cruise of our RV, we found that the front wheels of the coach were off the ground after using the auto-jacks.
We put a couple of nice jack pads under the front jacks to keep the jacks from being fully extended (suggested by RV service tech). We also put a couple of 12x12x2 PT redwood blocks under the front wheels.
After all that work, we noticed light or gaps between the hanging front wheels and blocks. RV Service Tech told me that was bad for the axles and the jacks. Trying to figure out how to solve this problem.
Should I use shims to wedge the tires front and back of wheels? or do something else. Seems strange to drive up on blocks when I have jacks, but I am new to Class A RVs, and perhaps naive. Moving the RV to a better spot is not always possible if the CG is full and due to a tree we could not fully use the 40' pad we were given (our coach is 31').
On our Winnebago Vista, we have a manual button for the jacks, but have not figured out how to use the manual button to raise/lower the coach. There is a auto-lower button but I assume that fully retracts all four jacks (have contacted Winnebago Tech Support given the manual was not helpful at all).
For those RV veterans out there, this might be a really naive posting but I really do not want to damage or coach or have a safety issue for my family.
  • I try to get my MH as level as I can using blocks before engaging the auto levelers. I also place blocks under the jacks so they don't have to extend as far. I just don't like them to be at the far end of the stroke.
  • It's really not a problem to have the front wheels off the ground except for it is a bigger step to get in the RV. Now if the rear wheels are off the ground it is not good, you need the rear wheels to be on the ground because they keep you from rolling forward or backward on unlevel sites. Your parking brake and trans. park position is on the rear.
  • I will Drive up on blocks to get close to level then manually level the rig using the jacks.
    I find that if there are any wheels off the ground, the rig is less stable. Therefore I always try to keep all wheels in contact with the ground.
  • The level in the coach indicated that we were level after the auto-jacks finished. The front left wheel was about 2-3" off the ground and the front right wheel was about 4-6" off the ground.
    Unfortunately, the best or flat part of the 40' pad was blocked by a tree limb that was the same height as the A/C unit.
    The manual jack instructions imply that I can lower the jacks front, back, left or right. See no instructions for manually retracting (raising) one set of jacks. The 'retract' button says 'all jacks'.
    I guess I have to be prepared to move sites if I cannot get the front tires lowered onto the blocks. Could be a major problem if CG is full.
  • Welcome to the forum. No, it is not hard on the axels, front or rear, to be off the ground. As John said, if the system is out of cal. your information packet should have instructions on how to recalibrate it.
  • Was the site so off level that the front had to go up that high? If not I think in the instructions for the jacks it tells you how to reset the auto level. It may just need to be recalibrate. If it still goes to full extension try using the manual method.
