- Flyfisherman128ExplorerIf you are asking if it can be used outside, yes it can. But it was designed for inside. It has no UV protectors in it and it will fade pretty fast. If you are using white it will yellow. There is accompany called Nudo that has exterior FRP.
- DaHoseExplorerIt sounds to me like you might be looking for a quick fix and will do a permanent later.
Again I say that we really need more detail of what you are trying to do and why.
Jose - clydedoerrExplorerNo, I wan5 to put it over tpo roof bad spot
- pauldubExplorerDo you have a fiberglass roof or otherwise?
- DaHoseExplorerIt's not clear what you are asking. Do you have a fiberglass nose cone that needs repair?
Jose
38,780 PostsLatest Activity: Jul 04, 2015
