My fuel gauge is malfunctioning. Sometimes it displays correctly but will move to a full tank when I know it is half full. Will appreciate any suggestion to fix this.
Before you replace the sending unit see if you can find a separate ground wire for it. If so make sure it has a good clean connection to the chassis. Some units have a separate ground and if you remove the ground the gauge will peg past full.
