paradise56's avatar
paradise56
Fuel Injectors for Winnebago
We have a 1999 Winnebago Adventurer, diesel. It started blowing black and white smoke about 20 miles out from our planned stop in a small town in New Mexico. We limped in and found a park. It was 5:00 on Sat. so on Mon. morning we drove to the closest truck service station.
They say it's a fuel injector that is stuck open. They suggest replacing them all, which makes sense. However they could not find a matching part because according to the original owner, the blocks on these coaches were cracked and Cummins recalled them and replaced them back in 2002. The previous owner upgraded to a 350 HP at that time.
Cummins apparently revises their parts and so we are sitting in this RV park waiting for this service shop to find a fuel injector. The parts they have found are back-ordered. They say they are not sure if they find a comparable part, that it will fit.
We are thinking that maybe the best course of action is to take the part ourselves and drive our tow vehicle to Cummins in El Paso, TX (the closest large city). It should help if they have the part in hand, don't you think?
Has anyone heard of this problem before? Have you any other suggestions?
  • Thank you all for responding to my post. I have made notes of all the info you shared. A few calls to Cummins in El Paso did help us find a set of 6 new injectors. They are being over-nighted from Denver. We hope to be back on the road by Friday.
    Traver8 (Terry)...thank you for your kind offer. We are in Deming, New Mexico which is a friendly little town. It is very hot so we opted to stay away from outdoor activities in favor of air conditioning. Deming has a nice museum but it was closed till Aug. 4th, so we found the movie theater and saw Lucy. Very good! Then we visited a local winery, Saint Clair, and did some tasting and buying. They have a very nice selection of wine. For those of you traveling this way, stop in with your empty wine bottles. They will fill and re-cork them with your choice of house wines for $3 a bottle!
  • BTW, don't drive or operate it at all with an injector stuck open or you risk burning hole through a piston.
  • Hi paradise56,
    You didn't indicate where you are except small town NM. There is a good Cummins dealership in El Paso as you may already know. What was previously said about getting the info from the engine dataplate is the key to locating the correct parts. There may indeed be backorders but the dealer should be able to help you locate parts.
    El Paso is home for me but I am currently living in Southeast NM for work. Don't know where you are but there are things to see and do while you wait for parts if necessary. I can provide some input if you can tell me where you are.
    Hope you can locate the parts promptly and that fixes the issue.
    Terry
  • Look on the side of the timing cover for the engine. You should see an eng. ID plate that lists HP, S/N, etc. This is the info a knowledgeable shop needs to order parts. With this they should be able to order the exact injectors.
