bgum
Aug 27, 2021Explorer
It sounds as though the fuel flowed until it got down to the bottom of your fuel pickup tube in the tank. If so there are several ways this can occur. It appears one of your readers has ruled out all possibilities which means it just didn't happen.
I would add some fuel and level the rig. At that point turn everything off and see if it leaks. Also listen at the generator to hear if a pump or small motor is running.
