Rick_Jay
Aug 27, 2021Explorer II
I don't believe the fuel line is a gravity feed. I say this because I believe the pickup tube comes out the top of the gas tank. I know it does on my rig (Class A, so it might be different.)
That said, it IS a siphon issue. If there is gas in the line and you open the line (or a leak develops), the siphoning action will allow the gas to continue to flow until either the siphon is broken or the level of gas drops below the pickup tube. Which will also break the siphon action.
Please be careful as your troubleshoot this problem. Make sure all of the leaked gasoline is cleaned up before you try to start the generator.
Good Luck,
~Rick
Good Luck,
~Rick
