Ralph_Cramden
Mar 21, 2018Explorer II
DSDP Don wrote:
"mist4life"......I may be wrong, but isn't the fuel pump and all the hoses part of the plate that the lock ring locks on. Spin the ring and remove the entire assembly.
Depends on the design / manufacturer, some have studs and can be a real PITA. On a side note I know, or should say knew, a local independent mechanic who took a short cut and attempted to grind those studs off with a die grinder. He's no longer with us, nor is his garage.
38,769 PostsLatest Activity: Apr 03, 2026
