wildmanbaker
Mar 21, 2018Explorer
The fuel pump assembly uses a flat gasket. Replacing the bolts that have broken off may be a big problem, because of a fire hazard. You can inert the inside of the tank, or fill it with water. DO NOT underestimate the residual gas fumes.
38,769 PostsLatest Activity: Apr 03, 2026
