77rollalong
Mar 21, 2018Explorer
remove all the gas you can out of the tank, then fill the tank full of water right up to the fuel sender and let it run for a bit, then using a mig welder with the tank still full of water weld a washer to each stud if its just at the surface of the flange, then weld a nut to the washer. if there is a bit of the stud sticking up put a nut on it and weld the inside of the nut to the stud.. when done you can drain the tank of the water, and rinse with some methyl hydrate and dump it again and let dry..
38,769 PostsLatest Activity: Apr 03, 2026
