wildmanbaker
Mar 22, 2018Explorer
I'm not sure the studs are the thread in type. I believe that they are spot-welded in, and if you do replace the studs, try to keep the same orientation so the fuel float and pick-up work correctly. The tank itself is fairly heave gage, and there may be a ring on the inside. Drilling and maybe tapping the tank may be an option, as possibly welding nuts on the inside of the tank, for new studs.
Good luck.
Good luck.
38,769 PostsLatest Activity: Apr 03, 2026
