Kidoo
Nov 11, 2014Explorer
DSDP Don wrote:
Kidoo.....The Centroid fuel sending unit has everything incorporated into it, including the fuel pickup. On your coach, you have a panel on both sides of the coach, just behind the front wheels. I'm not sure if the Cayman had dual fuel fills, but the panel where your fuel door is located, actually opens.
On the driver's side panel, look under the coach and you'll see two screws holding some tabs down. Remove the screws and the entire pane with lift up, its hinged at the top and will take a broom handle to hold it open. Once you have it open. you'll see the fuel sending unit, about a 18" in from the edge of the tank, right on top.
Side Note.....I'm my Diplomat, I removed the screws on these two panels that access the tank and added a latch mechanism. There is a lot of valuable storage space atop the fuel tank. I use to keep tire chains and a blue toilet tote in there.
Here is the Centroid link for adjustment.
Thanks,very good info, I will check this out.
38,782 PostsLatest Activity: Sep 02, 2026
