wildtoad
Oct 26, 2023Explorer II
Newmar has the strongest slide system in the industry. They do have some “rules” for their slide system. First before extending slides check the vertical gap between the slide and the mh. This is called the reveal. If there is a gap (on BOTH sides), extend slides, otherwise don’t. Newmar states that most of the time (perhaps not in op’s case) the gap will be best BEFORE leveling. They don’t say when to extend, before or after leveling, just make sure you have a gap.
I have leveled mine just to find no gap or a too close for comfort gap and de-leveled to find the gaps were good. Extended the slides, then leveled. Make sure you reverse the process in the same order.
All the twisting to the frame and slide from the leveling probably resulted in the slide not being square, but not enough to cause damage. You were indeed lucky.
38,782 PostsLatest Activity: Sep 02, 2026
