Mr_Mark1
Jul 31, 2013Explorer
Generally, a full wall slide does not affect the basement storage space. The one thing it does do is it covers the wet bay area when extended. So, if you are connecting the electric/water/sewer/cable, you might want to do it before you put the slide out so you won't be ducking under the slide.
I haven't seen a full wall slide where the compartments are attached and move with the slide. In that configuration, you don't have full pass-through storage.
MM.
MM.
38,773 PostsLatest Activity: Apr 24, 2026
