Mr_Mark1
Jul 31, 2013Explorer
Gjac wrote:
Sounds like they come both ways. But in order to have pass trough compartments the storage bays must be part of the MH body and not on the slide. I would think that this would be hard to get to when the slide is out. That is if you have bad knees.
Yes, to have pass-through compartments they are attached to the body.
Pluses for attached (non-moving) storage bays:
-you have pass-through storage.
-you can have an electric or manual slide tray for easy access (so, no bending under the slide).
-generally, no weigh limit depending on CCC.
Minus:
-you might have to bend under a slide if no sliding tray.
Pluses for sliding storage bays:
-no bending over
-no deep reaching
Minus:
-weight limit in storage bays
-look out for low poles, fences, water connections, electrical boxes.
MM.
38,773 PostsLatest Activity: Apr 23, 2026
