mustang652
Jul 31, 2013Explorer
Mr.Mark wrote:
Generally, a full wall slide does not affect the basement storage space. The one thing it does do is it covers the wet bay area when extended. So, if you are connecting the electric/water/sewer /cable, you might want to do it before you put the slide out so you won't be ducking under the slide....MM.
Ditto! My first Class A had two slides on the driver's side, so I learned real quick to do all utility hookups before moving the slides out and I always started with the power first. I've still got the marks on my bald spot to prove the lesson. My current unit, a Thor 34XD is a full wall gasser and the first to provide partial pass through storage. The drive shaft was boxed in and allows the area above the shaft to be used.
38,773 PostsLatest Activity: Apr 24, 2026
