Gjac
Jul 31, 2013Explorer III
Lobstah wrote:I can't quite visualize what you have in the slide out storage. Right now I store my bike in one pass tru and a 3 ft x 6 ft table, 8 ft ladder and 4 fishing rods in the other. Would I still be able to store these items in the full slide out storage?Mike and Trish wrote:Mr.Mark wrote:
The one thing it does do is it covers the wet bay area when extended.
Only if it's on the driver's side! Mine is on the passenger side, so no problem there. To us, the big advantage of the full wall, rather than two smaller slides on that side, is that it eliminates the bottleneck that many coaches have in the middle (when slides are out).
Actually, the side of the slide doesn't matter.
My full wall slide is on the driver's side, storage moves with the slide, and the wet bay is the last bay back on the driver's side, which is NOT part of the slide.
I have the driver's door, then a slide which goes the length of the living room, galley, and bedroom cabinets. That leaves about 4' at the rear of the coach, which is where the wet bay and electrical hookups are located.
And no, I don't have "pass-thru" storage, BUT when my wall slide is out, the last compartment closest to the front of the coach is exposed, and has an end-panel door that locks with a key. If you open that door, you can slide a 22' piece of lumber into the storage bays under the slide, as they are contiguous. Can't do that with "pass-thru" :)
Jim
38,773 PostsLatest Activity: Apr 23, 2026
