ILVMYGT's avatar
ILVMYGT
Furnace Ignition Question
I am helping a friend troubleshoot a Suburban LP furnace. When the furnace starts it take several ignitions cycles before it stays running. The furnace "lights" for a fraction of a second (a puff of warn air) then goes out, then "lights" again. It takes several of these cycles before it stays running. You can hear the gas solenoid click turning on the gas. As best we can determine once the gas is on it stays on. The Sail switch is also working since the gas and ignition is turning on. Is it normal for it to take several ignitions cycles for it to stay lit?
