okiejoe
Dec 18, 2018Explorer
Furnace problem
Ok furnace would start then in seconds go out blower still running the it would reignite the after a few seconds burner goes out again then finally it stays lit. I had the sail switch replaced didn’t ...
okiejoe wrote:
Well the original problem was shutdown at ingnition, I took and still doe shutdown 1 to 3 times before complete ingnition and each part improved it but after ingnition it would only run about 6 minutes then flame out due to duct restrictions from too many. Tight bends but now that’s solved. I got to take it back to him to check the ignitor and and just give really good check of the electrical system of the heater. So in a nut shell there are a combination of things that were going on but it’s narrowed down to just the failing ingnition. I’ve been using him for sometime and he always does me good.
