Bird_Freak
Aug 09, 2015Explorer II
Kidoo wrote:Kido, I have the same system you do. I also used the Dinosaur board and it just plugged in.wa8yxm wrote:
RE: Sail switch: If it is bad unit will not attempt ignition
Question you said it tries 3 times, DOES IT LIGHT all 3 times or not?
If it is not lighting do you hear the Snap Snap SNap of the ignition system?
If Snapping,m but no flame.. Gas jet may be clogged or solenoid bad.
If lighting, clean the electroid, it may be bad also the connection between the Mother board and the burner sensor/ignition point.
If that does not fix.. I'm guessing the tester at the dealer gave a false good on the board..
Mine the board was bad.. I went with a Dinosaur board replacement and well.. I was impressed by the design and quality of this board. MaDe the OEM look like... Junk.
It does ignite and burns 3 times, the heat comes on every time then it dies with 3 lights.
I saw the Dinosaur board. Did you install it like plug and play or did you have to relocate some wires?
