Britches's avatar
Britches
fuse box question
My motor home has has a 1987 Econoline fuse box my question is space #4 is a 7.5 glass fuse but there is only one metal clip to place fuse in the left metal clip is not there why ? does anyone know oh it is for the fuel pump solenoid which electric pump is in fuel tank
  • j-d's avatar
    j-d
    Explorer II
    Here's Britches' pic of her fuse panel
    I want to confirm this is a 460 V8 with carburetor and a single fuel tank with in-tank electric pump. Then I'll try to find a chassis wiring diagram.
  • It is not uncommon on older Fords with glass fuses to find a space with only one clip. It was unused in that configuration so they did not install the other clip.
    It is also easy to miscount or mis identify the fuse positions due to positions of the fuses, staggering of them and the difficult to read info molded into the plastic on the edge of the opening.
    Charles
    2007 Winnebago View 523H on a 2006 Dodge (Daimler-Chrysler aka Mercedes) Sprinter 3500 chassis (T1N). Bought Sept 2015 with 18K miles on it, Prog Ind HW30C, Prog Dymanics PD4645, Chill Grille, PML/Yourcovers.com deep alum trans pan, AutoMeter 8558 trans temp gauge, Roadmaster sway bar, Fantastic Ultra Breeze hood, added OEM parabolic mirrors and RH aspherical mirror.
  • Britches wrote:
    I want to put a picture of my fuse box on here but I do not know how can someone tell me please. Then I can explain what I am in question of
    Use this link to help you post pictures.
  • Need to upload to something like photobucket and then post a link.
  • I want to put a picture of my fuse box on here but I do not know how can someone tell me please. Then I can explain what I am in question of
  • Either unused or broken. Picture would help.
    Does something not work? Is there an unattached wire?
  • j-d's avatar
    j-d
    Explorer II
    Where have you been? Wondering about you just the other day.
    Your '87 has a 460 and carburetor, right? Fuse box in the underside of the dash, driver side? Do you know if there was ever a fuse clip on the missing side? I don't remember anything like that on the '83 we had, but I wonder if Ford stuck a clip in there to store a spare fuse.
    I replaced a fuel pump fuse with a circuit breaker. Can't remember the position. I think it only blew once but I decided I'd rather have a breaker auto-resetting than try to replace a fuse in the middle of the road someplace.
    This diagram might help
    This diagram shows a blank spot in #5
  • It is an unused position that someone put a spare fuse in. An active live slot needs two clips for power to go through.
