HpymilsExplorerDec 27, 2015FW water drainWe have a 2016 Forest River Forester. Can't locate the drain for the fresh water tank. Found a blue hose under the unit that appears to be coming out of the FW tank but there is no valve to release th...Show More
youngoneExplorerDec 27, 2015Blue hose could be over flow for fresh water tank. Mine is that color and bigger than the water supply line.
Related ContentGrey water tank won't drain completelyHouse battery drain30' Arctic Fox FW drainFresh water drainwater heater drain mod
