We have a 2016 Forest River Forester. Can't locate the drain for the fresh water tank. Found a blue hose under the unit that appears to be coming out of the FW tank but there is no valve to release th...
It should be in the compartment just behind the passenger side rear wheel. Inside is a black door with a latch. It's the blue one pointing down. Did you find it? You could have different model than mine.
