We have a 2016 Forest River Forester. Can't locate the drain for the fresh water tank. Found a blue hose under the unit that appears to be coming out of the FW tank but there is no valve to release th...
I think the mystery of the FW drain has been solved. There isn't one. I called several RV service departments. All but one said they had no experience with a Forester 2431. They one that did said they had one in to be winterized and found no FW drain. They couldn't get in touch with anyone at the factory because they are closed this week so they used the pump to drain the tank so that is what I did.
