We have a 2016 Forest River Forester. Can't locate the drain for the fresh water tank. Found a blue hose under the unit that appears to be coming out of the FW tank but there is no valve to release th...
Some RV, have a drain point that is "T"ed off the supply line leading to the pump. The RV I saw this in had the pump in an exterior compartment that sat lower than the FW tank. If your rig is tall it might have the same setup (the setup makes priming the pump easier). The drain valve was close to the T. There was also a FW system drain valve in the same area ( a T just after the pump. The compartment was insulated).
