HpymilsExplorerDec 27, 2015FW water drainWe have a 2016 Forest River Forester. Can't locate the drain for the fresh water tank. Found a blue hose under the unit that appears to be coming out of the FW tank but there is no valve to release th...Show More
gkainzExplorerDec 31, 2015have also seen FW drain lines with no valve ... a cap fitting screwed onto the end of the line is the only thing holding the water in.
Related ContentGrey water tank won't drain completelyHouse battery drain30' Arctic Fox FW drainFresh water drainwater heater drain mod
