nbking
Apr 24, 2016Explorer
Gas mileage E450
Could some of you give me an estimate on the gas mileage I would expect on a E450 Class C 32 foot long? I realize driving conditions, weight, personal driving habits all are factors however, I woul...
Desert Captain wrote:
"Probably in some cases the E450 could pull a hill in a taller gear than the E350."
Why? The E450 does not have more power than an E350, they both have the same motor and transmission. The E350 has 4:10 rear end and does not need the 4:56 that comes with the E450 {to handle the extra load}.
That's why the 350 will always be turning more slowly {as in burning less fuel}, than the 450. Also that same engine in the 350 will be pulling a couple of thousand pounds less {assuming both are loaded to their respective GVWR's}.
If you are going to be towing or loading heavy, as in near your GVWR, the extra payload (assuming there is any), of some 450's and lower rear end make a lot of sense but they come with a stiffer ride and less mileage. Many of the larger Class C's are so heavy to begin with due to slide(s), levelers etc. they may not have much remaining payload available right out of the showroom.
One thing to look for when shopping for an E350 is the 55 gallon {optional}, fuel tank that comes standard on the E450. IMHO: The standard 40 gallon tank on many 350's lacks sufficient range.
:C
