mhb1382
Oct 13, 2013Explorer
Gas mileage
Hello everyone, happy to join the experts. I am in the process of purchasing a 1999 Tioga 31 footer with 450 10 valve engine and I'm concerned about the gas mileage. Greatly appreciate feedback. Than...
pnichols wrote:Sabluka wrote:
Anyone use syn in the older V-10s?
I'm not quite sure how old "older" is, but I've been using Mobil 1 EP (Extended Performance) in my late 2005 E450 V10 almost since it was new.
We can average close to 10 MPG on level roads cruising at 55-57 MPH. We weigh 11,800-12,000 lbs. fully loaded. There's no engine sound at these speeds and the tach reads around 2000-2100 RPM. The E450 chassis has lower differential gearing than an E350 chassis, so gas mileage may suffer a bit with an E450 if you keep your foot in it too much. I've made up for some/most of our E450's lower differential gearing gas mileage hit by using tires on it of a larger diameter than what Ford usually delivers on the bare E350/E450 chassis going to RV manufacturers. Hence, we get the other advantages of the E450 chassis over the E350 chassis without suffering too much from it's lower rear end gear ratio.
