- BumpyroadExplorer
tork'd wrote:
"I think that a good coat of wax will do as much good as the pods"
my guess would be more
x3
bumpy - Don_DonExplorerWhy can't people believe there is no magical fix? Mt gosh people don't be so gullible
- tork_dExplorer"I think that a good coat of wax will do as much good as the pods"
my guess would be more - hersheyExplorerAs competitive as it is today for RV manufacturers or automobile manufacturers just for the bragging rights to claim they get 1/10 MPG more than the other guys and the amount of big bucks engineering they have to make those claims...its going to be very difficult for somebody to come up with something you stick onto a car that will convince me there is merit in a gadget.
I think that a good coat of wax will do as much good as the pods. - workhardplayha1ExplorerAnd they have special magnets that are attracted to fiberglass.
- EffyExplorer IIRemember the vortex/tornado you could put in your carb to allow fuel to enter the carb with more velocity?
And I think someone else already said it, but I have 5 of these on the top of mine already. They are called clearance lights. Thank goodness they are there or I am certain I'd be getting 3mpg instead of the 8-9 I get now. - DanTheRVManExplorer
gfs1943 wrote:
Hey, let's not be so hard on the guy -- I think he's on to something. It says on the Web page that "for every gallon of gas saved, 19.4 lbs of CO2 are prevented from entering the atmosphere". Since a gallon of gas only weighs about six pounds, these things are obviously creating matter!
the O2 part of CO2 is not in the gas it comes from the air. Since 2 Oxygens combine with the C in the gas you should expect the weight of CO2 to be a lot more than the gasoline.
I would expect these silly thing may or may not provide some minimal improvement like air tabs - BumpyroadExplorerI suppose those that don't want magnetic tail lights on a toad cause they will scratch up the surface, also won't want these magnetic ones?
put a set on your RV and another set on your toad and you will manufacture gasoline?
bumpy - Toot_McExplorerHay guys if they don't work for air drag you can put them on your gas lines because they have built in magnets, and we all know that magnets on gas lines work......!!!!!!!!
- gfs1943ExplorerHey, let's not be so hard on the guy -- I think he's on to something. It says on the Web page that "for every gallon of gas saved, 19.4 lbs of CO2 are prevented from entering the atmosphere". Since a gallon of gas only weighs about six pounds, these things are obviously creating matter!
38,776 PostsLatest Activity: May 14, 2026
