DrewE
Mar 20, 2019Explorer III
Yosemite Sam1 wrote:
A cheap Walmart inflator is rated for 130 psi.
Just buy one and carry it with you. You'll alway need one. The other, to always check balanced air pressures on all your tires after several hundred miles or in severely fluctuating weather conditions.
They say 130 psi, but if you need to add more than a couple pounds to a large tire you'll be waiting for a very long time (and the cheap inflators are not designed or rated for continuous usage). Even a standard car tire takes a decent length of time to inflate with one of them. The high pressure rating is perhaps useful with things like road bicycles where the volume of air required is pretty minimal.
I carry a small 120V compressor, a Fini AirBoss, which does very nicely at putting air in the tires while not being too large or heavy.
38,782 PostsLatest Activity: Sep 10, 2026
