Gjac
Mar 22, 2019Explorer III
I use a 120v compressor at home and Flying J's or Loves when I travel. I do carry a cheap HF 12v compressor just in case of a flat that will burn up if you try to inflate a 19.5 tire to 90 psi. In 15 years and 100k miles of travel I only had to use it once and a plug kit I carried. I was able to get about 40 lbs after plugging the rear tire and then drove a short distance to a gas station to top it off to 90 psi. I would not use a 12 v compressor from Walmart or HF to top off a tire.
38,782 PostsLatest Activity: Sep 10, 2026
