rgatijnet1
Apr 21, 2018Explorer III
The trick is to set a tank level, say down to 1/4 tank, and then stop at the first station that has room for you to pull in. Usually this is an end pump but depending on the stations layout, sometimes we have used an inner pump.
If you wait until you are close to empty, not only could you damage your "in tank" fuel pump, but you could also minimize your chances of finding a station to fill up. Flying J and the other major truck stops are usually the most expensive places to refuel while some of the outlying stations may be quite a bit less expensive. We very seldom will fill up at a major truck stop unless we have other things that we need there, that we cannot get elsewhere.
