- Mike_WExplorerI know many of you are having fun beating each other over the head with your experiences and I too enjoy it. And I for one, still deciding, find it useful. Any additional detail or depth on cost related items would be great. Like is it really $235 for an oil change? They just tried to charge my daughter $75 for one on an older sedan, so maybe 235 isn't that far off? Can that job be done DIY? Again, this is helpful. Thanks
- As others have said, my decision was cost. For the same floorplan, the diesels were $75,000 more than my gas Class A. For the amount of miles I put on the motorhome a year, that cost didn't make sense to me. I guess if I lived out west and was driving in the mountains all the time, I might have considered paying the extra cost.
I know the Smokey mountains are not the Rockys but I have driven a lot of miles in the Smokeys towing our Jeep and my gas Class A did just fine.
Burch - pianotunaNomad IIIHi LandYacht35diesel,
I have never been to Hawaii.
As far as I am aware I did not have an Allison transmission.
There were lots of other issues--but the log book is not in my possession.
I have had almost zero problems with my E-450 v10. - LandYacht35diesExplorerRichard ... what specifically failed ? Could you have adapted a Allison trans to a BBF ? I know they have adapters for a big block Mopar.
Now spending THREE LARGE on that upgrade would be money well spent ! - LandYacht35diesExplorerpFish ... 235$ oil changes ? ... how many nights of lodging in Hawaii do you get with that ?
Two transmissions? You only need THE ONE that came with it ! The Allison transmission is virtually BULLETPROOF..... the only thing that stresses them is way WAY overloading them. - GeeWillakersExplorerFor us a 32’ works. Looked at diesels in the 32-34 range and they had less storage than our gasser.
- RLS7201Explorer II
LandYacht35diesel wrote:
RLS7201 wrote:
I'm going to go with cost. Right now my gasser transmission is sitting on my garage floor waiting for the replacement to arrive. $3K for the HP tranny and I'm doing the R&R. Couldn't do that at home with a diesel.
Richard
Richard .... my man .... 3k$ for a Fix Or Repair Daily transmission......
Sounds to me you got ...... DICKED !
I’ve done HUNDREDS of transmissions over the years .... just Mopars .... you should have gone on a Ford site before spending that kind of coin.
Bottom line .... the transmission biz is a HUGE RACKET
Well I didn't tell the whole story. I have a stroked 460/528 engine with RV cam, compression raised from 8.4 to 9.0, Banks complete power pack and a little porting.
All that took out the stock transmission. I could find no one in the Midwest willing to build a high performance E4OD with low stall converter and triple disc clutches in the converter. Steel baskets and 6 planetary gear sets. Plus some other nice little touches the shop offered.
The converter alone is a $800 item. For the package I wanted, I found pricing ranging from $8K to $4.5K. + freight.
I am well pleased with $3K, which includes shipping both ways.
Tell me how much you could build such transmission for and maybe we can do business next time.
Richard - LantleyNomad
To add ... people saying diesel maintenance is too high ?
Like what ?
LandYacht35diesel My 1987 was on a Ford 350 chassis and was a FRED.
1. additives to every tank of fuel
2. oil changes at $235.00
3. 3 sets of fan belts
4. 2 transmissions
5. having to have shore power or a generator for starting in cold weather.
6. failed glow plugs 2 x
7. failed power steering 2 x
8. failed house isolator
9. failed grounding wire to dash
10. failed starter
11. front tires needing to be rotated every 6 thousand miles
12. failed fuel line. I had to have them cut out the heater and use generic fuel line.
13. failed starter solenoid
14. failed transmission cooler
These are a few of the many problems I and my brother had.
Only a couple of those items are exclusive to diesel.
Fan belts, transmissions,starters can fail on any engine even the gas powered ones.;) - pianotunaNomad III
Like what ?
4. 2 transmissions
10. failed starter
These are a few of the many problems I and my brother had. - Alex_and_TeeExplorerCopy and Pasty
38,766 PostsLatest Activity: Jan 10, 2026
