Bill_Satellite
Jul 01, 2017Explorer II
Jim Norman wrote:Bill.Satellite wrote:
My coach exhausts the generator to the rear of the coach. If you are there, I must apologize in advance. You are going to get gassed! I do what I can but I am not buying an special hardware to mitigate the problem. If you are parked in a 24/7 generator area you are going to have to assume that folks are going to run their generator A LOT and few (if any) are going to do any special to deal with the fumes.
Frankly that is a hell of an attitude. Most or many places that allow for a generator to be run REQUIRE a stack. Also it is more likely to kill you than me. I slight wind shift and the fumes will be under your rig and drifting up through it as opposed to blowing into me. So when you wake up dead from saving $120.00 for a Gen-Turi stack, please don't come crying to us.
Frankly, it is not. I have NEVER once been in ANY place that even mentioned a stack. The FMCA rallies certainly don't. Parked at Wal-Mart? Nope! Not sure where you think you were that REQUIRED you to use a special after-market product that NO RV manufacturer or RVIA or any other governing bodies believes to be required much less necessary. If I am running my GenSet 24/7 then all of my windows and vents are closed and the exhaust is being blown away from my coach. If there is enough wind to blow it back toward my coach then it has already been dispersed enough to be non-lethal and it still needs to find a way in. I have done what I do for many years (over 17 fulltiming) and it has never once been an issue "for me" but I have had some folks who decided to park closer to me than they should get upset. That's not my fault and there is nothing I can do about this. Personally, I don't want gas heavier than air above the roof of my coach and "assume" that Nature will take care of dispersing this gas. I like to keep the gas low and blowing away from my coach.
If you don't like it, I really don't care. If you are parked behind me, move. I got here first!
