dougrainer
Apr 10, 2015Nomad
rgatijnet1 wrote:
It is really neat when it decides to crank up the generator at 2AM.
Auto Genset start, most have either the Temp to start or the Low Battery voltage threshold to start. Almost ALL can have quiet time to be set, so that the Genset does not come on between the Quiet time that is set. Usually that is 10 pm to 6 am. But you can program your own quiet time. Adding depends on the brand and model of the Inverter/Charger you have. Also that will determine what parts you need to purchase. ADDING AC temp to start is more costly as you need to run wires from the roof AC control boards which are usually on the roof in the AC unit. This option has been around for almost 20 years. It is not something new. Doug
38,783 PostsLatest Activity: Sep 24, 2026
