John Wayne wrote:
They work the problem will be your next door neighbor at the event with a diesel pusher will be parked with his generator exhaust facing your door and he will not have his vented to the top of his RV. So all his exhaust will be coming into your rig.
When in "generator only" areas of rallies it should be a requirement for signup and when setting up. It also should be required on RVs with diesel fired hydronic heating with the mid-coach exhaust. We no longer attend rallies and opt for "generator only" areas due to getting gassed on two different occasions by a neighboring RV's hydronic system running for heat and pumping the exhaust "under" our RV with prevailing winds. Alarms went off and wife and dogs got sick. We had a Gen-Turi, they had none.
