hotjag1's avatar
hotjag1
Explorer II
Jun 16, 2019
Generac generator quits power output...UPDATE
The smaller motorhome in my signature has a 5500w Generac generator that is not producing current at higher loads. The generator starts and runs fine when using the coffee maker or the microwave, but when I turn on the AC, the compressor will run for about 10 minutes and then the generator stops producing any current to the motorhome but the Gen does stay running.
If I shut the Gen off and restart it, it starts producing current again as long as I don't run the AC more than a few minutes.
Why would the Gen stop power after 10 minutes of using the AC?
  • Low oil level or pressure, and over temp will shut the engine down. That’s what those two sensors are protecting.
    Maybe a self-resetting circuit breaker somewhere?
  • Since it continues to run, it sounds more like the ATS than the overheat shutdown. Does anything else other than the AC continue to run? Is there a code on the panel?
  • akrv wrote:
    Went to a rally in Cashmere WA it was a 100 degrees the whole time. Every one that had 5500 generacs would shutdown when the AC was running and air temp got over 98 degrees. Turns out there is a high temp oil switch maybe yours has same problem. Almost all the units were 98-2004
    That's a good thought as it has been pretty hot here. Did the Gens quit running or stop producing power? Mine keeps running but power output stops.
  • Went to a rally in Cashmere WA it was a 100 degrees the whole time. Every one that had 5500 generacs would shutdown when the AC was running and air temp got over 98 degrees. Turns out there is a high temp oil switch maybe yours has same problem. Almost all the units were 98-2004
