Sounds as if you have the dreaded Generac starter problem. Mine had 985 hours on it when I got the MH,used,and started right up,for a month or so. Then it started doing what you're describing and then nothing. Took it in to the shop and he said the Bendix was melted to the starter and the starter actually looked pretty new. Found in the P/O records that it only had 20 hours on the gennie since it had been changed,but P/O hadn't put down the name of the shop. We changed the starter 3 times before we found one that lasted more than 10 starts. The last one lasted a year and now has started doing it's slow turn and finally a click. I redid the grounds and it didn't do any good. I did discover that my 4 y/o batteries were toast and so got 4 new 6v and still no good. Battery boost crossover doesn't do any good either nor having the engine running.While trying to recharge the old house batteries,they wouldn't take a charge from either the onboard charger or my 25amp aux charger, I slid under the front and hooked the battery charger to the gennie cables and after 6 hours it went from full 25 amp charging to a 5 amp charge and I tried to start it with the charger still hooked up and a 75amp push from it. Nope... No good. I am going to try disconnecting the battery cables to the gennie and just hitting it with the 75 amp starting boost from the charger. When I don't know as I'm in the middle of a bathroom emergency rebuild. The Dw decided that since I was redoing the totally plugged galvanised drain pipe and had the vanity off the wall,that now would be a good time for new flooring,vanity,toilet and wainscoating on the wall. Kinda over my head,but I'm actually muddling thru it towards a sucessful and neat ending.
