gtp's avatar
gtp
Generator AC question
The front AC unit does not turn on while running the generator. The rear AC unit does work on the generator. The front AC unit works hooked up to shore power. So there has to be some link between the front AC and the generator that isn't correct. Any ideas???
Thanks in advance.
  • We just turned on the front one. When it didn't work, turned it off and tried the back. That one worked. Never had a problem before. Of course the one we use the most while traveling is the the front, so really want to solve the mystery.
  • How big is the generator? Its entirely possible its not capable of running both and other things at the same time so its not wired to be powered that way.
    Just a guess from a layman.
