tatest
Apr 06, 2014Explorer II
It will cause you to use an additional .5 gallons per hour. How that impacts MPG depends on how fast you are running.
If you are using 8 gallons per hour to run 60 MPH (7.5 MPG) then the additional .5 gallons reduces MPG to 7.05, not quite 1/2 MPG less.
If you are using 5.5 gallons per hour to run 50 MPH (9 MPG) then the additional .5 gallons reduces MPG to 8.25, about 3/4 MPG less.
If you are standing still running the generator, MPG is reduced to zero, because none of the fuel being used moving you.
38,778 PostsLatest Activity: Jun 10, 2026
